Re: air in shower line
Posted by e-plumber on February 01, 2004 at 11:53:24:
In response to Re: air in shower line
: The shower continuously 'pulses' with air in the pipe, causing low pressure. How do I eliminate this problem?
Reply:
If you're on a well system for your water supply this problem may occur throughout the entire plumbing system in your home. If it is only in the one shower, I would think there is a possible problem with the diverter allowing the water to pulsate, making it appear that there is air coming out of the faucet.
Good Luck. e-plumber
Replies to this post
There are none.
