| Posted by e-plumber on February 01, 2004 at 11:12:30: | |
| In response to Re: Building a custom radiator | |
: Hi all, : I would like to convert a one pipe monoflow hot watr system to a baseboard loop. The problem is that the job spec requires I keep the radiators under the windows only. Doing so will not allow for suffucient BTU output. I looked into various types of alternative radiators, but was shocked by how expensive they became. : My question is, can I build my own custom radiator by stacking one baseboard elemnt on top of another adn if so, should I pipe the water flow through one then the other using lots of ells, or should I use a monoflow tee to divert the flow through each element. : My guess is that I am not the first person to think of this, so if there happen to be any commercially available solutions like this, I would love to hear about them too. Thanks! : Charlie Reply: |
| There are none. |
