Re: Constant Circulation?
Posted by e-plumber on January 31, 2004 at 07:58:44:
In response to Re: Constant Circulation?
: Hello All! : I have a newer Burnham boiler on a hot water heating system with radiators. Would there be any benefit to wiring up the circulator to run 24/7? Also, are there after market outdoor reset controllers available? : Thank you! Reply: I don't see any benefits at all. I do see problems though; overheating, extra wear and tear on the boiler and its components, major waste of energy, the list goes on. Why would you want to? Is the home not heating up adequately? Your boiler may be undersized or there is air in the system preventing proper circulation. A service tech should inspect it and possibly give it a tune up. Good Luck. e-plumber
Replies to this post
There are none. |
