| Posted by hj on January 30, 2004 at 22:48:30: | |
| In response to Re: Leaking Delta Bathroom Sink faucet | |
The rubber washer is inside the faucet, but now you also have to replace the stem because you "broke" it. : The Delta faucet in the bathroom sink was leaking.When I took it apart I found ther was no rubber washer, only a flat piece of metal. I bent the metal piece just a bit with a screwdriver and put it back together and it does not leak, at least for now. Is this the proper way to repair this type of faucet?
| There are none. |
