Re: leaking jacuzzi
Posted by e-plumber on January 30, 2004 at 20:07:35:
In response to Re: leaking jacuzzi
: We bought a house that has a built-in jacuzzi in the basement. The problems is when we fill it (500 gallons) we have to put about 100 gallons in it a day because it keeps going down. We haven't noticed any water in the basement or anywhere else. What do you think the problem is? We had it up and running for about 3 months. I know there will be some evaporation with a "pool" of water at 95 - 100 degrees, but can it be this much?
I would imagine that it has a drain. The stopper may not be holding 100%. If so, disassemble it, clean it/adjust it. Or replace parts if needed.
Good Luck. e-plumber
Replies to this post
There are none.
