| Posted by laleh on January 30, 2004 at 17:56:49: | |
1. What do I wrap ABS pipes that are being in slab that is about to be poured? 2. I'm a newbee, please send all advice on running copper lines under ground (from house to garage). I am concerned about heat loss (water heater is in the house). What do I use for this and to protect the pipe from being damaged? How deep do I barry them? 3. Is it better to have the male end of a water line stick out of the sheet rock so the flex lines can be screwed on easily (or should I leave it where it will be barried by sheet rock)? The flanges I'm about to use are almost flat so they will not cover much. Thank you all in advance, Laleh |
| There are none. |
