Re: My sister has a problem
Posted by Gary Swart on January 30, 2004 at 14:51:38:
In response to Re: My sister has a problem
Sorry, you have some bad information. The problem is the drain IS clogged. The only "air lock" would be from not have a vented drain. Two things I can tell you. First, do not, repeat do not use a chemical drain cleaner. If you already have, tell the serviceman when, what, and how much was used. These don't work and create a hazzard for anyone working on the system. Second, do call a professional plumber who can professionally power auger the drain. I know it will cost something, but it's the only way, and DIY alternatives could cause damage the drain system that would cost far more to repair.
Replies to this post
There are none.
