| Posted by hj on January 30, 2004 at 08:52:18: | |
| In response to Re: Radiator balancing | |
If every radiator has a thermostatic valve, you do not balance them. You set the thermostat in each room for the desired temperature and it shuts of when that temperature is reached. : I am removing the old radiator valves and replacing them with TRVs, however I am unsure of how to balance the radiators on completion. Can you help?
| There are none. |
