Re: Temp/pressure relief valve
Posted by hj on January 29, 2004 at 23:07:53:
In response to Re: Temp/pressure relief valve
The first thing would be to assume the valve was doing its job by releasing excess temperature and/or pressure. Only after you have determined that the heater did not malfunction, should you assume a bad T&P valve and replace it.
: I have a gas water heater and last night I noticed that I had hot water continuely running out of the temp pressure relief valve pipe. I turned the inlet water off and it stopped, other than replacing the TPR valve what else could it be and how can it be fixed.
: Thanks for your help.
Replies to this post
There are none.
