Re: Toilet Flush Tank - Keeps Refilling
Posted by hj on January 29, 2004 at 23:02:02:
In response to Re: Toilet Flush Tank - Keeps Refilling
You may have thrown away the small plastic device for the end of the refill tube, and stuck the tube into the fitting on the top of the overflow pipe, (you should have pulled that fitting off and thrown it away), and now the little tube is too far down into the overflow pipe and is sucking water out of the tank.
: Our toilet keeps losing water out of the tank and keeps refilling. We replaced completely the entire flapper mechanism. But, it still does it, like clockwork, every three minutes. Any solutions?
Replies to this post
There are none.
