| Posted by hj on January 29, 2004 at 22:58:42: | |
| In response to Re: replacing or relining pipe | |
This could be one case where the cheapest estimate could be the best one. The amount quoted seems to be quite high for the job you are describing, and you do not even know if that is really the problem, or how extensive the problem is. : $5K to $6K is a lot of money, but that may or may not be an excessive charge. On a job this big, you should get at least 3 estimates from different contractors. If someone comes along that say they can do it really cheap, run as fast as you can. As far as who to call, you live there and should be able to check company references.
| There are none. |
