| Posted by hj on January 29, 2004 at 22:56:22: | |
| In response to Re: toilet | |
The Eljer Triangle toilet does not come under that code. But to make it look right, the toilet stub pipe has to be a least 12" from both walls, and ideally the two measurements should be the same for aesthic purposes. : i am finishing my basement. the stub out for the toilet in the bathroom, however, is only thirteen inches from the outside wall and about that from the other wall making up the corner. in other words, i cannot turn the toilet in either direction to make it fit the code. i am contemplating a corner toilet made by eljer. would that meet the code (fifteen inches from the center of the toilet to any sidewall or other obstruction)?
| There are none. |
