Re: Toilet Problems Since Tapping into City Sewer
Posted by hj on January 29, 2004 at 22:54:04:
In response to Re: Toilet Problems Since Tapping into City Sewer
The problem with the two toilets will not be solved with an air admittance valve, and one could make the problem worse. The sink/washer problem might be cured with an AAV in the correct location, but given these two different problems one has to wonder who installed the original plumbing system. It has nothing to do with connecting to the sewer system.
: I have two bathrooms one on the main floor, and one directly above it on the second floor. Ever since we tapped into the city sewer a few months ago, when you flush the upstairs toilet-- the downstairs toilet bubbles (very large bubbles!), almost to the point of splashing out. Could this be fixed somehow with an air admittance valve? If so, how....if not, how?
: Also, whenever the washing machine in the basement is draining into the laundry tub, the kitchen sink on the floor above it makes a gurgling sound from the trap. Could this be fixed with an air admittance valve?
: Thanks for your help!!
Replies to this post
There are none.
