Re: New Drain installation leak
Posted by Clay on January 29, 2004 at 21:19:07:
In response to Re: New Drain installation leak
The coupler I'm talking about is basically the same as what you mentioned; accept it probably cost me more. It's essentially, 1.5 diameter pvc tube that's threaded on both ends There's a slip nut and washer which go over the pipe at the wall (which is some kind of metal and its corroded a bit--which could be the problem)and a slip nut and washer which connects the coupler to the tube which is attached to the p-trap. I hope that explains it.
Cheers,
Clay
Replies to this post
There are none.
