Re: Shower Drain Replacement
Posted by Charles Hall on January 29, 2004 at 11:18:23:
In response to Re: Shower Drain Replacement
Is it possible if there is enough room between the concert floor and the shower pan, to cut an opening on the wall close to the floor and reach under neath the shower pan and tighten up the drainage nut? Turning the drainage from the top of the pan just doesn't pull up the nut to close tight the loose drainage. This is why the water leaks onto the concert floor. Shower has not been used for over two years. help! help!
Replies to this post
There are none.
