| Posted by Deb on January 28, 2004 at 23:36:04: | |
| In response to Re: New Drain installation leak | |
: when I Installed a p-trap for the vanity sink that I put in my bathroom. I'm having a problem with the connection from the drainage pipe in the wall to a coupler valve which is connected to the p-trap. A leak is occuring right at the wall. : When I use the drain with water turned on full no leak occurs. When I fill up the sink with water however, then unplug it, the leak occurs any help is greatly appreciated. Tell us more about this "coupler valve". I don't knw what you are talking about. |
