| Posted by hj on January 28, 2004 at 19:19:28: | |
| In response to Re: installing a standard dishwasher as a rollaround? | |
You would have to construct a plaform with wheels to put it on, then make 3 sides and a top. Finally you would have to buy the water/drain dual hose and retracting reel so it could be connected to a faucet. By the time you finished you would probably spend as much as a true (non-convertible), portable would cost and still have something that would look obviously home made. : I am just inquiring about the possiblity of turning a standard dishwasher into therollaround movable type. If it is possible what kind of modifications would have to be made to the water line in and the drain out. And since it runs on 110v could it be modified with a standard plug? Any thoughts would be appreciated . cheers .
| There are none. |
