Water Sensor & Electric Well Shut Off, Pressure question
Posted by Dave on January 28, 2004 at 13:55:11:
Is there ANY product out there that is designed to shut off the power to a well pump when it senses a water leak? I have seen the WaterCop devices; they only block the flow. That's all and good, but I am interested in stopping the pump if I have a leak. That way, if I had a leak ANYWHERE (maybe before the WaterCop valve), I would only allow the amount of water in my system into the house rather than have the pump keep pumping and pumping and pumping... Also, would it be a good idea to install a backflow prevent valve on my main water line? I am concerned that the pressure from my system may eventually wear my well pump out. Am I crazy?
Replies to this post
There are none. |
