| Posted by e-plumber on January 28, 2004 at 11:51:51: | |
| In response to Re: Thanks for advice on drainage problems! | |
: Thanks for the advice you post here for all of us as its very much appreciated! I used some drainage remover but it was using the plunger that helped or did the job. I had to plunge several times and for about 20 pushes as someone kindly recommended here. I kept using the plunger when I would've given up had I not read that advice and hung in there. : I'm starting to suspect as its been noted here several times that there is something clogging or catching in the drain line. I kept thinking it was frozen somewhere as the problems I've had has only been during very cold temps and only this year (Eastern Long Island). : Is there any type of drain "cleaner" that I could put in that would remove any build up along the line? Obviously, if this continues I'll call a plumber(Trying to make it to spring). Do they work from the clean out pipe/vent in my garage (on slab)? : Again, : Thanks! : Neelie Reply: |
| There are none. |
