| Posted by hj on January 27, 2004 at 22:23:28: | |
| In response to Re: Heat pipe runs through Tub | |
Galvanized pipe cannot be soldered. But you could have BundyWeld tubing which was a steel, copper tubing sized material which could be soldered when it was new. I am not sure how it would work after all these years. : I want to install a new bathtub in my second floor addition but the hot water baseboard heat runs through the old steel/enamel bathtub. The pipe runs behind the basin/bathing area and through the built in front skirt. The the hot water baseboard does a complete loop around the inside perimeter of the upstairs. Pipe that doesn't have heating fins is still enclosed in baseboard. I do not wish to run the pipe through the new tub but I'm not sure how to run it. IS there any reason I should not just drop the pipe into the floor and pop it up again to continue the loop?
| There are none. |
