Re: Roughed in Basement Plumbing
Posted by hj on January 27, 2004 at 22:21:00:
In response to Re: Roughed in Basement Plumbing
You have to place the riser in the spot where a waste and overflow outlet would be, which is not under the tub outlet, but mostly under, and behind, the overflow opening
: I have roughed in basement plumbing for a tub, toliet and sink. My questions is the tub/shower drain is 16 1/2 inches from my cmu wall. When i go to fram the tub enclosure should I center the tub drain directly over the roughed in drain, or should i offset it enough to accomodate an s or p elbow. The rough in has a pan of loose cement, I will be breaking it loose tonight to see how deep it is.
: Thanks Cpt
Replies to this post
There are none.
