| Posted by torbett co on January 27, 2004 at 20:03:46: | |
| In response to price : watts 1" u5b | |
: : : My water pressure reducer has evidently failed. I get water squirting out of the relief valve of the water heater early in the morning and in the afternoons. I put a gauge on a faucet and it read 175PSI this morning at 6:00AM. This reducer has been on less than four years. The water company says we have up to 230 PSI on the public lines here. : : : What type of reducer should I buy. Is there an industrial grade that will handle reducing from over 200 pounds down to 50 or 60? Should I put in two? If so, specifically what make and model? I have found that most of the advice I get at the building supply houses is not very dependable so I thought I would inquire here. Thanks. : : Reply: : Post Message: I put in a Watts N250B today and the pressure seems to be holding at 75PSI. Is this too high? Do I need to install a second reducer or can I actually adjust the N250B down to about 55PSI. I have heard you should not try to adjust them?? I put in a thermal expansion tank a couple of years ago. The screwy thing is my nighbors do not seem to have the problems I have??
| There are none. |
