installing new dishwasher
Posted by mike edwards on January 27, 2004 at 15:25:49:
ive read a lot of your post regarding adding a dishwasher. thanks for the help so far. i have an older house with cast iron drain plumbing, my sink runs to a vertical cast iron drain pipe in the block wall, my old dishwasher doesnt run to the sink or the garbage disposal, it actually goes through a rubber hose directly to a tee on the same cast iron vertical drainpipe in the wall, seems to me like there is no trap involved in that old configuration and i might get sewer gas entering the dishwasher??? my main question is whether i would be better off running the new dishwasher drain to the disposal which would require cutting thru cabinets or use the existing hookup. thanks in advance for any help or advice you can lend me.
