Re: GURGLING NOISE IN TOILET
Posted by Deb on January 27, 2004 at 10:33:41:
In response to Re: GURGLING NOISE IN TOILET
: Just moved into a newly built home 4 weeks ago. No problems with plumbing until today. While taking a shower, I heard gurgling noises that sounded as if it was coming from the toilet. The water in the tub was not draining properly at that time either. When I checked the toilet, there was very little water in the bowl but the tank was full. A second toilet on the same side of the house also had very little water in the bowl but the tank was full. The toilet located on the opposite side of the house in the MB didn't have a problem at the time, nor did the toilet upstairs. Later when my husband took a shower in the MB he also heard gurgling noises. Should we give it a few days to see if it goes away or call the plumber. Thanks. Get your plumber out now. The gurgling is almost always indicative of a clogged drainage line. Unfortunately, it is not unusual for construction debris to get in lines. Deb The Pipewench
Replies to this post
There are none. |
