| Posted by Tubby on January 26, 2004 at 19:54:22: | |
| In response to Re: Raising Toilet | |
#1) Wax ring will be just fine. #2) You can buy a piece of Santana (the material not the rock group) and cut it to form the bottom of your toilet. Santana is nothing more than high denisty plastic that is up to 2" thick and 4 by 8 sheets. You could use marine plywood or even marble for the same thing. I would do this before going to the trouble of trying to cut off the existing pipe and remounting a flange. hope this helps. |
| There are none. |
