| Posted by e-plumber on January 26, 2004 at 18:00:29: | |
| In response to Re: Pressure balance with Circulating Pump. | |
: Hello, : My question is a slight bit unusual and technical(not really). The questions is in regards to a remodel project in a 100 room motel. The property is about 15 years old. What I would like to know is: : Will a recirculating pump maintain constant pressure? This pump is only on the hot water side; currently : Do I need AntiScald Valves if I have two recirculating pumps; one for the hot line and the other for the cold line.? : How do I know if the current valve mixer is anti-scald or not.? : Thanks in advance Reply: |
| There are none. |
