Re: Running Toilet
Posted by Hube on January 26, 2004 at 13:59:57:
In response to Re: Running Toilet
: After the toilet is flushed and the tank fills, the water keept running. When I hold up the ball float, it stops but the minute I let it go--the water starts to run again. The tank is filled to its normal capacity. I'm afraid to fiddle with any of the srews or the ball float because I don't want to make it worse. I manged to get the flow stopped by holding the ball float up and very carefully letting go; but expect that I'll have water flow problem after future flushes. My guess that is't something simple, so hopefully someone out there can tell me what to do.
Just BEND the float arm down a touch and by doing this it will shut the flow off sooner. Hube
Replies to this post
There are none.
