| Posted by Chris on January 26, 2004 at 13:19:53: | |
| In response to Re: Side Inlet Wye Question | |
: That is not a side inlet "Y", it is a side inlet combination Y-1/8 bend and as such the tub inlet is not vented properly because the actual vent "opening" is below the inlet to the fitting. But it is academic, since I doubt that you would ever find one unless it was special ordered and might take months before they made it for you. But the tub inlet is opening into the vertical portion of the vent in either case (side inlet of the sanitary tee or the side inlet of the combo wye), right? Sigh...and I thought that I was starting to get the hang of this. I think you're right about it being academic, though! Thanks for your time...this is a great board. |
| There are none. |
