| Posted by hj on January 25, 2004 at 21:27:30: | |
| In response to Re: Basement bath venting | |
All the fixtures need vents and the existing drain pipe cannot be used for your vent. The water draining from the upper level can cause a positive pressure in the new drain system and an AAV cannot handle positive pressures. : I'm adding a basement bath (toilet, shower & sink) and need to know venting requiements. : There is a first floor half bath above that vents through the roof. So right now there are two fixtures on this stack. The bath I am adding is directly below. The toilet will be 1' from the stack, shower will be 3' and sink 4'. : Do all three of these fixtures need to be vented? Is AAV a good choice? If vent is required I need some help with the toilet. The toilet will sit almost directly over the existing horizontal line making a vent difficult since it will not run horizontal and the is almost no verical room. The only thing I see working is a sanitary tee with a inlet. : Thanks for any advice.
| There are none. |
