: I have installed 2 diverter valves (american Standard)but they keep malfuntioning.The rubber at the end of the valve rips open after using for a month or so.The plumbing supplier said to put grease on the end,so I did.It did not hold up,any help would be appreciated. call american standard and describe the problem and give model number of fixture if you have it, something inside may be cracked. They are usually pretty good about replacing parts and fixtiures, hopefully it isn't too old. good luck
