| Posted by Deb on January 25, 2004 at 13:31:13: | |
| In response to Re: Side Inlet Wye Question | |
: Here's a question for you real plumbers. :) : Picture a toilet and shower on opposite sites of a partition wall with a 3" stack vent in between. The drain needs to turn horizontal at the base of the stack. There are no fixtures higher on the stack. : My first thought was to use a 3x3x3x2 side-inlet sanitary tee to connect the toilet and shower to the stack. Below the sanitary tee the stack would go into the leg of a combo wye to do the horizontal turn with the cleanout. (This is #1 in the picture). : So I thought about using a combo wye directly under the toilet for the cleanout/horizontal turn, feeding horizontally into a combo wye with a 2" side inlet to take the shower drain. (#2 in the picture) : Is this kosher? Specifically, is there a problem with having the shower trap arm enter the stack only a few inches above the drain? Does anyone have a better solution to this problem? Thanks and sorry for the length! I have never seen a side inlet wye.... |
