Re: bleeding oil furnance
Posted by e-plumber on January 25, 2004 at 12:02:40:
In response to Re: bleeding oil furnance
: I fix a pipe that burst naturally the water drained and now i need to fill the pipes - help! Reply: It sounds like you have a HW heating system. Open the valve that you shut to do the repair and go to each radiator and open the bleeder until water comes out. Make sure the circulator(s) are off. If you have baseboard heating, you may have purge valves at the boiler for air removal. If you're uncomfortable doing it, call a professional. Good Luck. e-plumber
Replies to this post
There are none. |
