| Posted by Hube on January 25, 2004 at 09:26:05: | |
| In response to Re: Pressure switch | |
: I have a Gould shallow well pump. Can a pressure switch cause problems with getting air in the lines, causing the pump not to pump properly. I replaced the foot valve and still have trouble having the pump act properly. I wondered if the pressure switch could be the problem. Thanks The pressure switch is probably ok, but any LEAK in the intake pipes can cause this "air" problem. Check for and seal all leaks. Good luck, Hube |
| There are none. |
