| Posted by Chris on January 24, 2004 at 22:16:18: | |
![]() Here's a question for you real plumbers. :) Picture a toilet and shower on opposite sites of a partition wall with a 3" stack vent in between. The drain needs to turn horizontal at the base of the stack. There are no fixtures higher on the stack. My first thought was to use a 3x3x3x2 side-inlet sanitary tee to connect the toilet and shower to the stack. Below the sanitary tee the stack would go into the leg of a combo wye to do the horizontal turn with the cleanout. (This is #1 in the picture). So I thought about using a combo wye directly under the toilet for the cleanout/horizontal turn, feeding horizontally into a combo wye with a 2" side inlet to take the shower drain. (#2 in the picture) Is this kosher? Specifically, is there a problem with having the shower trap arm enter the stack only a few inches above the drain? Does anyone have a better solution to this problem? Thanks and sorry for the length! |
