| Posted by Tubby on January 24, 2004 at 17:26:47: | |
| In response to Re: Tub won't Drain -- I can't snake down either. | |
The bath tub drain can easily be cleared with a decent shop vac. This works only if you know the problem is with the actual tub drain line and not the main. Suck the gunk out of the drain through the overflow (hole in the side) while you have something over the bottom drain. I have pulled coins and bottle top out of the traps with a 5HP shop vac. just and idea for this pesky drain... |
| There are none. |
