| Posted by hj on January 24, 2004 at 17:02:37: | |
| In response to Re: Jacuzzi tub installation problem | |
Even if the tub is set first and the tile is done afterwards, it should go under the tub rim, which is why I said it is harder for the tile man to do it that way, since his tile bed has to be set so it is the exact distance below the tub rim for the tile to slip under the rim. : : Either way. It is easier to connect if the tub is placed first and the front is open to connect the drain and water, but it is harder for the tile person, because he has to work to an exact measurement. Tiling first reverses the two. The tile person has an easier time, but it is harder for the plumber. It just depends on whether you have a better plumber or tile person. : Does it matter in terms of possible future leakage? If the tub is on the tile or if it is against the tile?
| There are none. |
