Re: Expoxy Resin- Plumbers mate QUICK QUESTION
Posted by Vince on January 24, 2004 at 10:46:07:
In response to Re: Expoxy Resin- Plumbers mate QUICK QUESTION
You should have never used that stuff in the first place. You should have made a proper repair.
The problem now, you to your own making, is that you may have to replace the entire unit. That stuff really sets up, but never make the water tight seal it promises. You will have to cut out the damaged piece and replace it.
The top shell of the water heater is the most important part of the heater next to the gas control valve, T&P valve, tank, and the remaining outer shell less insulation.
Just last week I ran into a similar situation where someone tried to repair something, well let me tell you...I'm glad to be alive!
It will bust right off.
Replies to this post
There are none.
