Re: Rheem Hot Water Heater - Burner Can't Stay Lit
Posted by hamid ghahraman on January 23, 2004 at 22:38:20:
In response to Re: Rheem Hot Water Heater - Burner Can't Stay Lit
: I'd look at the gas pressure. Have a qualified plumber check the pressure at the unit.
: Also have him look at the entire system to see if the water heater was added to a line or if the heater has it's own line.
: Do you just happen to have another gas using appliance running when you notice the water heater problem?
Replies to this post
There are none.
