Re: heat cast iron joint or dig out?
Posted by LonnythePlumber on January 23, 2004 at 21:21:08:
In response to Re: heat cast iron joint or dig out?
: My washer drains into a cast iron pipe with a sharp bending trap and then goes directly into one of the main vertical waste pipes in my house. It slows regularly and water overflows into my basement. I'm thinking of removing the cast iron and replacing with PVC. Should I heat the cast iron joint or dig it out? Dig it out. LonnythePlumber
Replies to this post
There are none. |
