Fiberglass howere pan leak
Posted by Rick on January 23, 2004 at 16:25:29:
I have a fiberglass shower pan installed on a concrete slab, and the PVC drain is leaking very slowly. I believe the leak is coming from around the rubber or neoprene gasket installed between the 2" ABS pipe and the inside of the drain. The gasket is made by C-P Industries Part #6326. The drain itself has a largw W stamped on it, but no name. So far, I have been unable to locate another gasket. I'm not even sure the previous owner used the correct gasket. If I find the new gasket, is it possible to dig out the old gasket for replacement? One store advised me to use 100% pure silicone over the existing gasket. I/m really trying to avoid tearing out the whole neo-angle shower and starting over. Any advice would be appreciated, Thanks
Replies to this post
