heat cast iron joint or dig out?
Posted by Brian on January 23, 2004 at 08:48:03:
My washer drains into a cast iron pipe with a sharp bending trap and then goes directly into one of the main vertical waste pipes in my house. It slows regularly and water overflows into my basement. I'm thinking of removing the cast iron and replacing with PVC. Should I heat the cast iron joint or dig it out?
Replies to this post
