| Posted by hj on January 22, 2004 at 14:06:42: | |
| In response to Re: Leak Testing before Installation? | |
If I understand your question properly, you can test anything you want, as much or as little of the installation at any time. Just cap or plug any loose ends and put a pressure test on the section you are concerned about. : I am in the process of installing a gas heater and gas cook top stove. What I would like to know is there a way to leak test fittings before they are installed?
| There are none. |
