| Posted by hj on January 21, 2004 at 23:09:08: | |
| In response to Re: Bath faucet hot and cold reversed | |
Without knowing the make and model we cannot tell you if it is possible to reverse them without opening the wall, or how to do it if it is possible. But regardless of whether it is backwards or not, they should still mix to give tempered water. : Bought a new home that has a guest bathroom with a tub faucet - single handle dial-type. Hot water and cold water are on the wrong sides and don't mix - it turns off when it is in the middle. How do I fix this, or do I need to replace. Don't know type of faucet.
| There are none. |
