Re: help, outdoor hose bib leak
Posted by gb on January 21, 2004 at 19:36:56:
In response to Re: help, outdoor hose bib leak
: Again, if you stop the water flow and the temperature is below freezing, the pipes will freeze. If there is a cut off, that is only half the battle. You would need to drain the pipes or heat the crawl space, but be very careful about this, every winter homes are burned to the ground by folks trying to heat crawl spaces.
:Thanks for your reply and information! I will just let it leak for now and fix it asap.
Replies to this post
There are none.
