Re: help, outdoor hose bib leak
Posted by Gary Swart on January 21, 2004 at 18:39:42:
In response to Re: help, outdoor hose bib leak
It is likely the drip is preventing the pipe from freezing, and if you put the hose and noozle on and stop it from dripping, it will likely freeze and possible brust. Insulating will not help. Insulation does not generate heat, it only helps retain it. Is there a big problem with just letting it drip until you can fix it? If possible, open it and let it do more than drip.
Replies to this post
There are none. |
