| Posted by Gary Swart on January 20, 2004 at 16:55:00: | |
| In response to Re: Air in Pipes | |
Air from what pipes? Water pipe? The plumber worked on the drain pipes which, hopefully, are not connected to the water supply pipes so his work would have nothing to do with your problem. Air from drains? If that's what is happening, I don't have a clue, but it would be time to get a plumber on site to figure out what is happening. The auger to clean the line should be a professional sized power auger, not just a long coil. |
| There are none. |
