| Posted by Tony on January 19, 2004 at 14:45:28: | |
| In response to Re: bathroom sink pop up drain assembly | |
: I replaced my bathroom sink pop up drain assembly and can't stop it from leaking. The water seems to be coming through the threads at the top of the assembly. Should I use teflon tape to fix this?
The thing I can't figure out is, where does the water tha falls between the drain and the holes that appear on the side of the drain pipe that slides into the sink go? Does it remain in their until it dries up (mind you that is the water that is leaking from the bottom seal in my case) or does it stay there and eventually cause an odour to appear.
