Re: Leaking Faucet
Posted by Prabhu on January 19, 2004 at 00:32:11:
In response to Re: Leaking Faucet
thanks for the response..
The bath tub faucet has a small lever on it top. The shower can be turned on if the lever is pulled upwards and push it down to stop shower.
What should i do next ?
: : You did not describe your system, but naturally there is some device which you push or pull or turn to divert the water from the tub spout to the shower head. That is the mechanism which is in need of repair.
Replies to this post
There are none.
