Re: Two water pressure reducers?
Posted by Brantley Thames on January 18, 2004 at 22:51:09:
In response to Re: Two water pressure reducers?
This is a little different from the question above...About how much should a PRV cost? Also how much should a 50 gal water heater run me? Include cost of delivery and installation for both...just a ball park. Finally, what happened is that my water heater essentially exploded ruining my basement. I had a new water heater installed (for about $1400). Then the pressure was apparently too high in the system (120psi) so the new water heater leaked due to the high pressure. The same guy then came back to say that a PRV needed to be installed (for about $500) to bring the pressure down. After this was installed, the water heater still leaked. Aside from firing the company working on it you know any reasons or solutions to this problem. Thanks for any help you can offer
Replies to this post
There are none.
