| Posted by steve on January 18, 2004 at 21:15:14: | |
| In response to Re: water hammer | |
Are your water pipes in your house secured (strapped) well? : : : When my automatic sprinkler valves come on I get water hammer in the pipes of the house. I know this is common when water shuts off but in my case it happens when each of the valves open. I have a pressure regulator on the main house supply that is set to 60 psi and I installed a water hammer arrester in the supply line close to the sprinkler valves and it has not helped. Any ideas? : : Reply: : I have checked it with two different hose bibb type gauges only a few inches from PRV. PVR is only a month or so old. Any other ideas?
| There are none. |
